HUAWEI GT2 Pro Update Problem
microdemic
New member
Just did a firmware update on my watch. I believe the version it is 10.1.3.28. After the update the heart rate sensor no longer works. Any suggestions to get it working again?
WatchSmarty
Member
Staff member
A few things you can try:
Reset the watch
Unpair the watch from the app and delete the app.
You can then reinstall the app and connect to the watch again.
WatchSmarty
Member
Staff member
One other thing you can try is to let the battery drain completely. Then recharge. This may get the sensor working again.
microdemic
New member
Draining the battery completely and recharging solved the problem. Seemed to have reset everything. It is working now, hopefully it continues. Thanks for the help.
Waleed
New member
Hello There, I have the same problem, I tried to drain the battery but it seems to have some kind of protection, it shows battery 🔋 as zero percent but it keep turn on for a few seconds then turn off again, I repeated the process over fifty times and still not completely drained. Any advice?
Thank you in advance
Waleed
New member
The watch was working like a charm before the update to the new firmware 11.0.5.32.
When the installation completed the sensors went off, it would be weird if the official firmware update break the watch :(
I have sent a ticket to Huawei, and waiting for their advice, I will definitely update here.
Top
